how to know which file is syned with the d5 renderer.
Where does it display the file address path that is syned last in D5 Renderer??? This is so hard and annoying that it is so hard to track that down.
Syncing a new sketch up file does not recognise the material and I have to do it all over again. Is it just me? What and where am I donig it wrong? Or D5 is designed that stupid in this case?
  • If the Resync option is available, you will be prompted with a window that shows the file location.
    Screenshot 2025-04-17 065501
  • You can also try to open your D5 File, then another empty SKP File (saved), activate the Plug-in. You will be prompted with this window in D5 that shows which file you have linked.
  • To sync an updated SKP file with an existing project (assuming identical composition and material names), first open your D5 file, then the SKP file, and finally activate the plugin.
