How to improve the appearance of trees?
Does anyone know how to improve the quality of vegetation when there is a contrast between the light of the sky and the trees? The image below was rendered in 4k.
Sometimes it seems that the leaves of the trees are too reflective, leaving the vegetation whiter than green.
Hi, thanks for posting. First, it is suggested to use HQ assets for high quality. Then you can use material picker (shortcut i) to select the materials of leaves, then edit them in batch ( the color, and the Specular parameters, etc).
Besides, maybe you can check whether exposure value is too strong, then adjust that with auto-exposure turned off.
