How to fit if the material scale is different
I’m using rhinos
Perhaps because of the vector value, if the material is used for different sizes of mass, the scale of the material seems to be different
Is there a solution to make this the same scale?
Hi there
Do these 2 surfaces have the same Map Type settings in Rhino? Which type are you using? Or are you using UVW? D5’s UVs follow the modeling software. Additionally, may I know the following:
  • Rhino Version
  • D5 Render Plug-in Version
    Rhino
  • If it’s possible, you can send us your rhino file at support@d5techs.com and have it titled “Clov-Forum How to fit material in Rhino”
Thank you.
