Good afternoon, I would like to know if I can create my own animated blocks for D5 Render? And if so, how do I do it? Thanks
Hi! For animation, D5 now support abc. format.
BTW, could you describe more details about your need?
In fact, I would like to have my own library with animated blocks, for example in this video below, this toaster I made this animation and I wanted to create a block of it to use in other projects
Hello, was your animation created in D5?
I created this in the d5 render, there are two separate objects, the toaster and one object and the bread is another. I would like to know if I can create an animated block of this animation
I’m sorry, I don’t think we support this feature at the moment. Maybe you can try to make animations in other software and then import them into D5, currently we support abc format.
I will also feedback your comments to our team.
