I’m trying to animate an object in D5 Render, but I need to change its pivot point to make it move and rotate properly. Is there a way to do this in D5?
Hi, in the tutorials they explain how to do it, you have to import the fence or door as an object but it must have the center of the XYZ coordinates on the side where it can rotate, so in the video you give it the movement.
Hi, exactly, I’m adding this video too, you anticipated me, I think you will understand better in this video ![]()
Thank you very much, both of you. It really helped me
