i saw some video on d5 website…so i need help…how can i make this animation effect?anyone have any idea?
There are many ways to make animations like this, you can use it directly in D5 or use other supporting software like 3Ds Max or Blender,…
if im import from the blender, the material is gone…and all becoming 1 object…3ds max im still trying right now… about d5 i havent have any clue to do this…
have you differentiated textures in Blender before importing? How did you import the Blender model into D5? Have you tried to download the D5-Blender sync plugin?
to import as a animated building i export it as abc files. if i sync directly from blender…it will not become animated building…it just a building…
Hi!
Currently, the import of .abc files with textures is not supported in D5. You will need to separate the textures in modeling software and then re-apply them in D5. We will consider adding support for this in future iterations. ![]()
You can also check this info here: Why is the dark side of the video darker compared to the output single frame? - User Manual (d5render.com)
You can consider FBX format, D5 supports importing FBX with materials, but it doesn’t support importing FBX with skeletal animation for now.
