[Hot Issue]D5 Crashes when "Save As" or "Save" is used (opening the file explorer)---Qt window conflicts with other DLLs
Muchas Gracias. Seguí las indicaciones y ha funcionado, el problema se soluciono.
La versión que estoy utilizando de D5 Render es 3.0.1.
Ela, today you are my favourite person in the whole world. !!! I wasted so much time on this yesterday and now it is solved in 5 minutes!!
Hi @projects11 @wladtobar
Thank you for the update. Glad to have helped!
You are the best Ela. For now it seems that the issue has been resolved. But I’ve been having this problem since I used sketchup live plugin in D5, can I use this plugin again? If problem happens again, May I reply to this comment to ask for your help?
Hi @202303052
You’re very welcome — I’m really glad to hear the issue has been resolved.
Yes, you may continue using the SketchUp Live plugin. By the way, could you also let me know which version of the SketchUp LiveSync plugin you’re currently using?
Thank you, and don’t hesitate to reach out anytime.
I already tried deleting the part they mentioned, and also renaming the “usr.ini” file, but the problem persists.
Hola tengo exactamente el mismo problema, lograste solucionarlo? al abrir el usr como indican ni siquiera me sale el texto que debo borrar, estoy desesperado y no encuentro solucion en ningun lado :confused:
Hi @dortizt6 @arq.leastudillo
I’m sorry for the inconvenience caused. Could you let me know which version of D5 Render you are currently using? Also, have you had a chance to try the suggested workaround?
Hi I am using the 3.0.1 d5 version
Live plugin for Sketchup 2021 (But It works perfectly now, thank you so much!!)
Hi @1079822
Have you had the chance to try the workaround mentioned above?
yes I tried the * Rename the local files in the D5 \framework\ folder (MSVCP140.dll & _1.dll) to .old and now it works thank you
please help, I tried everything said up here but nothing works
Hi @21-00968
Thank you for reaching out. Could you please elaborate on what exactly happens on your end when you use “Save” or “Save As”?
  • Does D5 crash immediately after clicking the option, or when the file explorer opens?
  • Are there any error messages displayed?
  • If possible, could you share a screenshot or screen recording of the issue?
Also, may I know which version of D5 Render you are currently using?
how you fix
