Hide / invisible textures
Hello!
I am not quite sure, if its already implemented, but I would like to be able to hide textures.
Could be placed under “Material Template” called “Invisible”. I tried to use “Transparent”, but sometimes it does show up on renders.
You can use “Custom Alpha” and then give a black map to the alpha map. That would make the texture invisible.
How to make materials invisible in D5 Render - Get Help / AnswerHub - D5 RENDER FORUM
