why gtx1650 can’t run the program i use a labtop and i can’t upgrade it cause it’s too expensive of course and am still a student what can i do to run the program ?
Hi there @mahmoud1shehta
The minimum requirement for D5 Render to run D5 Render using an NVIDIA GPU is a GTX 1060.
Although the GTX 1650 was released around 2019, compared to the GTX 1060, it still falls short in terms of performance (the 1650’s predecessor is the 1050, and the 1060’s successor is the 1660). Additionally, and certainly the reason why it GTX 1650 is not supported, it does not have dedicated RT (Ray Tracing) Cores. Hence, D5’s minimum requirement starts at the GTX 1060 graphics card.
so you say there’s no other way for me to use the program ![]()
thanks tho
Unfortunately, yes, given the current GPU that you’re using. ![]()
