I’m facing a small issue while working with animations. When I duplicate a clip, the animations I added to objects in the original clip don’t get copied to the new one. Is there any way to duplicate both the clip and its animations together?
If this isn’t possible right now, is there any alternative or workaround to avoid redoing the animations for the new clip
I apologize for the inconvenience this issue has caused. I have tried duplicating a clip with objects that have Animation and it seems to copy everything including the inserted action. Please check this video recording: Duplicating Clip with Object Animation
Does this issue only occur in other files as well? Or is it file-specific?
It would also be best to provide us with a screen record of the issue being evident.
You can also send us your file so we can test it on our end considering that the issue did not persist on my side. You may send it to support@d5techs.com and have it title “Clov Forum - Duplicating Clip with Object Animation”
