d5 render error on out of video memory trying to allocate a rendering source. Make sure your video card has the minimum required memory, try lowering the resolution and/or closing other applications that are running. Exiting…
what should i do as i open sketchup and end up getting that after waiting for it to load
sorry for your situation. Please tell me your graphics card, usage of Dedicated GPU memory and Memory when running this D5 file. Besides, are you using a laptop?
Yes, I am using a laptop. My graphic card is NVIDIA Geforce RTX 3070 and the memory is 32G which is why I am not sure why the video memory or there is an error?
Hello, @e0775458
The message “Insufficient memory on graphics card” may be due to insufficient graphics memory/memory. You have 32 GB of RAM, but it’s currently at 90%; D5 relies heavily on video memory and only reads ‘Dedicated GPU memory’, and generally D5 will crash if the video memory is over 80% occupied. Is this a large scene you are running? Does this popup appear when running other scenes, such as a D5 demo scene? I suggest you increase the memory stick/optimize the graphics memory usage.
Optimize graphics memory usage
The following settings are available for optimization:
Start D5 Render with administrator privileges and restart your computer. The program will automatically modify the TDR values, which can improve the stability to a great extent.
Turn on DLSS.
Depth of field, Tyndall effect, and other settings can take up a lot of video memory, so use your discretion.
Higher resolution mapping will also take up video memory, you can replace the mapping of materials farther away from the camera with a lower resolution mapping and try to avoid using replacement.
More reflective scenes will reduce efficiency, you can turn the specular of materials far from the camera to 0 to cancel the reflection.
Windows’ own GPU usage data may not be accurate, we recommend using GPU-Z. Check the sensor-memory used parameter for better memory management.
