No idea what I did, but when I switch between scenes, the object group would be visible in one scene, then another scene would have object group greyed out and I no longer can see models even though the visibility toggle is set to “ON”.
Hi there,
You may need to check your layers in the scene. A layer must be “Hidden” which causes the models to be hiddin as well.
Cheers,
Aryan
Thank you so much! that fixed it. ![]()
