Hello)
I use free grass scatter
when I reduced the grass it turns out that they are in a row
how can I mix them so that they be not in a row
thank you )
but i need use scatter because it has more settings and i can make more realistic grass
So if you have to use the scatter you have to select more grass leaves, in the drop-down menu on the top left where there are the materials, objects, particles and also scatter just choose and create the terrain you want
and so on
thanks)
i see in your portfolio this picture. How didi you create the grass?
Please help me to create grass like that. Please show print screens of the settings of this grass. Did you use free scatter preset?
Hi, in this work I used Displacement, why did I use this method for grass?
Now I’ll explain, since I have a laptop of a certain power with the 16G GTX 1070 card and the i7 processor with another 16G, I felt that when it comes to large jobs like these and to have a certain fast processing time I I use PBR.
I’ll insert an image of the material with the settings you posted
It’s the PBR of the herb
If you don’t like this one, there are many on this site of different sizes
https://www.textures.com/search?q=grass
PS: In the PBR setting I changed from sRGB to Linear, this is because, to make the grass less dark but appear greener and brighter, then with the effects in the Saturation part I lowered it by adjusting the environment. It depends on whether one likes it or not.
Good work
Thank you))
