hello, I have a problem with the grass material, it looks 2D, how it can be solved ?
Thank you.
I think it comes from the curved surface because it’s working normally on plane surface any solution?
Thank you.
is the 3D grass possibly hiding on the underside?
Bye
Andreas
Hi mate, it’s actually not perfect, but we are improving.
I believe that as one of the main features of D5 is how well it handles polygonal grass, you should put some on this face, as long as your GPU can handle it.
hello, try to transform the surface into a solid (even a minimum thickness) and give it a parallelepiped mapping
It has already a thickness but the grass doesn’t apply correctly on such slopped or curved surface.
Hi mate, we will improve the performance of grasses with the curved surface in the further. thank you for your feedback.
