Hi there!
Thanks for awesome tools in 2.3 version, love it so much!
However I got a problem with editing grass material geometry offset from object border. Is there an option to decrease it?
Summary of this topic:
Question: gaps at the edge of grass material template
— We have noticed this. And our team are working on it. For now, you can fill the gap by adding the grass model from Asset Library with the Brush tool.
Hi there, it’s normal because we will leave some gaps at the edges due to the issues with how we developed the grass material. We will improve the feature later. For now you can fill the gap by adding the grass model from Asset Library with the Brush tool.
Kind Regards.
I just updated to 2.3 too, and now my grass looks like being done by a kid, lots of blanks LOL,
seems like the only way to solve it is to paint it like @April_Lee saidm haha
Such a shame really. I made the switch from Lumion because I thought the newly added grass feature might compare to it but with this border offset it’s pretty much unusable. I don’t intend to manually paint over all the edges, hoping to achieve an unnoticeable transition between the grass material and the hand painted stuff. Because no matter how I set the size, random size etc, it never looks like the grass material. What’s the suggested solution on achieving a quick and easy realistic looking patch of lawn?
Sorry for the inconvenience. Because the grass material is mainly designed for long-distance view, there will be gaps. For a closer view, it is suggested to use the brush or scatter tools to paint the grass. And if you want to fill the gaps using the grass with the same height or size, we are sorry that you need to place the grass model, adjust the size and then duplicate the model.
No it’s not normal. This is happening starting from v2.3, didn’t have this issue before. Imagine having a huge project and have to fill the gaps this is a huge pain in the buttocks and happened to me last week.
I think I have identified the problem which seems to be related to the converter tool! After adding grass to the project as soon you update the project from the host programm (Sketchup in my case) the grass density at the borders diminishes greatly leaving big areas “uncovered” which is really problematic when working on big projects. I think there is a position shift of the grass, don’t know why. And by the way better grass rendering would also be nice together with the ability to dynamically adjust size and appearance after having applied it to the desired areas. At the moment it’s very rudimentary.
I really love the improvements in D5 and the speed you guys are delivering BUT honestly, I would rather have a super stable program than having new features every month and bugs everywhere! I’m addressing that because another issue in my opinion is the way GI is calculated. But this is off topic, I already posted my concerns in the appropriate section. Hopefully v2.4 will fix this.
Do we have an update on this being fixed?
I have a project where I have many small grass beds so scattering 3D grass assets is not worth the reduction in performance and a grass material will suffice.
Having used the grass material in Enscape renderer, it performs as expected with grass being generated to the edge of the object the material is applied to.
Please could this behaviour be integrated into D5 in the next update, I would expect it to be a quick fix, adjusting the grass offset to be generated all the way to the edge!
