Glass milky/frosted effect
Hi there team - not sure if this a bug or just me unable to understand how to achieve this? I want this massing concept building to have a glass texture but frosted/milky feel. I did play with the roughness and spectacular settling but for some reason I just can get it to look like the example below.
Even if I use the Frosted glass texture from your assets library it does not work.
Please help.
Thank you.
Example 2
Example
I had similar problems!
Hi there! Thanks for your report, we will add this material in the future! For now, you can try to use a noise texture and paste into normal. Hope this will help you!
Thank you Team!
Use the ‘White Gauze Curtain’ under ‘Fabric’ and play around with the Metal/Specular/UV/Opacity/Normal/Roughness settings to get something close to what you need.
Like this:
Or this:
Great! Thank you Gary.
W
