Attempting to use the Fireworks 02 asset, and noticed that the pause function does not actually work. It would super useful to be able to freeze explosions for still renderings across multiple copies of this asset.
Attempting to customize the Fireworks 05 asset, and noticed that you can change Color 01, but Color 02 has no options and just shows a black UI window when you select the drop down menu for it.
Hi there; I apologize for the incovenience. I have tried the asset that was mentioned in this topic and the “Pause” button seems to be working fine. If you change the color of the asset, you might want to toggle the “Pause” button since modifying its color will allow it to play/move. Perhaps, a screenshot or video recording of the issue you experienced on your end will be helpful. Thank you.
