Excessive intensity minimum bloom effect
In D5 Render 2.7 bloom effect has excessive intensity even with the minimum value of 0.01.
I have tried lowering the intensity of the emissive material and lowering the bloom effect to a minimum, but it is still too intense. In D5 Render 2.6 it didn’t happen. Any solution forfor this bug?
Greetings.
David.
Hello, does this excessive bloom effect appear in the preview? Or does it appear in the render? Would you mind showing a screenshot of the problem?
It’s only appearing in the render, not in the preview.
I suggest you send your scene file to us and we will check it.
You can share a link here or send your file to our email. (support@d5techs.com, please describe the problem and attach the link of this post to your mail)
0.1 bloom effect apply.
That’s the minimum value, but the effect is still too bright… And there is no difference in intensity if I increase the bloom parameter to 0.2, 0.3,…
Hi! Could you please tell me which version of D5 you are using now? I also suggest that you can show us your system info. :heart:
Of course! Here you have, in the last update (updated today), it still happens:
Captura de pantalla 2024-05-27 091446
Captura de pantalla 2024-05-27 093609
This is the minimum bloom, here re-rendered:
And this is D5 viewport:
Hi! Does this issue only happen in this scene or it occurs in all scenes? BTW, I suggest you can send your scene file to us. We will check it to find what caused your problem. You can share a link here or send your file to our email. (support@d5techs.com, please describe the problem and attach the link of this post to your mail)
In scenes not created with the latest version 2.7, coming from 2.5 - 2.6, it happens in all of them. But I created a basic scene with the same lighting characteristics, and the bloom effect with 0.8, 0.2, and 0.1 has clearly different intensities.
Bloom 0.8:
Bloom 0.2:
Bloom 0.1:
Thanks for your testing. We will check this issue.
Hello. This issue should be caused by a relatively large optimisation of the GI in 2.7. So if the effect of the previous version is significantly different in 2.7 from the original performance, it will need to be readjusted. Why does the scene made with 2.6 or previous versions look different in version 2.7? | User Manual (d5render.com)
