I have a 3ds file I converted into .D5a using the plugin and when I try to bring it into D5 render using import, it shows a yellow dot and I can’t place it on my scene.
Hi, we are going to release a new version of the 3ds Max plugin this week, and it should fix the problem you met. I will keep you updated here.
By the way, what version of 3ds Max do you use?
Same problem here, 3dsmax 2021
Hi @razvanoprea @elocobes please try the new release of 3ds max plugin, which should have fixed this problem. Download | D5 Render
awsome!, thanks!!
