Error executing program with version 2.3
I’ve try to open the program but It’s keep shutting down after 2-3 second of home screen.
here is the log file
zziplog.zip (1.9 MB)
this is video link for this issue
Not sure what to do after several installation
NOTE- Version 2.3.0 and 2.3.4 , I’ve the same problem about program executing
but when I’ve try version 2.2 It’s can run properly
PS- my GPU is AMD Radeon RX 6950 XT
REGARDS
Hi mate, I checked the log and found that it should be related to your video driver. Your video driver is 22.Q4, which is not compatible with D5 yet.
[Hot issue] D5 Render cannot open or get stuck at 15/85/99% #20221031 - Get Help / Tech Support - D5 RENDER FORUM
Please check this topic to revert your video driver back to 22.8.1.
Thanks,
Oliver
Thank you, It’s fixed with 22.8.1 version of AMD driver
