Edit D5 textures
Hi!
Is it possible reach and edit (with photoshop) D5 textures?
Where exactly are they saved?
Hi, when you have a D5 texture that you would like to modify, just look in the textures folder of the files you save in D5, that is, when you work in D5 with your work and use a texture from the program and then save it in a folder with a specific name, a series of folders is formed, where there is the D5 file that you saved, in one of those there is the texture of the material you used.
Good work
Hello, if you are referring to the texture maps in our library, these are currently encrypted so you cannot export them individually.
