If you’re encountering the issue that the saved files fail to load in D5 Render, it is probably caused by
Too many plants in the scene
Too many high-resolution (16k) HDRIs used in the scene
The Repair Tool is for clearing the overloaded resources in the scene, which helps to open the file successfully. It must be installed in the installation directory of D5 Render 180. Please backup your project and exit D5 Render before proceeding.
Note:
This is a temporary repair tool for Version 1.8.0, for urgent project needs
Please reduce the use of high-resolution(16K) HDRIs. If multiple scenes need to use custom HDR, it is recommended to use the copy parameter feature of the scene list, or use lower resolution (4K) HDR
The issue is expected to be fixed and optimized in Version 1.8.1.
can I have DRS repair tool for version1.9.0 as Im having problem to load my drs file that stucks at 5%. I have lots of plants in the file , as I am doing a projects involves plants landscapae thank you
The .drs repair tool cannot support the 1.9.0 version. Please send your logs to my email for analysis, I have downloaded your file but cannot open it too.
Please send us the two logs for further investigation:
• Win C: “%local appdata%\d5_immerse\Saved\Logs”
• Installation Directory of D5 Render: “D5 Render\logs”
This repair tool was only used for version 1.8 before. A corrupt DRS file may indicate that you have transferred the .drs file to another location outside of its designated folder. If so, please revert back to its original location.
You can also tell us how your drs file got corrupted.
