Hi, you can also do in another way, if you have the frames of the entire building, just perform the cloud of the points with the orthophoto, such as when you use Google Maps to capture a group of buildings and with rendercoc builds you buildings of an area urban. Using blender in the reconstruction, in the end you have this result:
I tell you this because you have the opportunity to do any render is video without implying yourself on the movement of the drone
I also show you a tutorial:
But and also interesting this other method too:
If you notice well you can build your palace, from the imagines of the drone, then export it in the format you want, I recommend you sketchup in SKP, if you know how to use it cleaning it and you can import it to D5 in your work you are doing
Good work
May I know your workflow? If you are using 3dsMax or Blender which allows you to set up a camera animation that is similar to having a drone, you may want to ensure that you are using the latest version of the Plug-in. You will then see this icon, which sends your current camera motion track.
