Hello everyone, is there any way to fix those DOF artifacts?
Hello, to confirm, this happens only to image rendering, right? Please make sure your D5 Render version is the latest 2.3.4.0931/0932.
Also, you can try lowering the blur value.
Hi Oliver, thanks for answering.
I just downloaded the D5 again yesterday so it´s the latest.
I just did an animation for testing. It´s much better but it has a little bit of flickering and a kind of a sharp edge at the end of the dof
I know that decreasing the dof could fix some of the issues but would be better in future to have a good dof on any dof situation.
Hi ThiLima,
Thank you for the updates. Yeah, we will improve this feature in future.
By the way, did you turn on Round Corner for that material?
I rendered with and without round corners, I also tested with and without supersampling… but the results were pretty much the same. If you need any other tests let me know if I can help.
Thanks a lot for the answers ![]()
