Diffrent result still image and video
hi d5 team, I have a problem with the video rendering results, the shadows on the video look darker than the still image, is there a setting I can change to give the same results on the video? thanks
left still image, right video
hi, may i know for video render. what is render workflow , are u exporting .mp4 video or sequence render.
if you are exporting video then there is a strong chance that still and video quality mismatch.
try sequence render and check is there still difference.
let me know update.
yup i use .mp4, oke i will try the sequence render
hi, is ur issue solved.
Hi @krisnayudi654,
Could you please confirm whether you are seeing consistent results in the preview, and if the differences in the shadows are only visible in the rendered version? If possible, please share this file with us so we can test the issue on our end. I apologize for any inconvenience this may cause.
Kindly send the file to support@d5techs.com using the tag Anthony_Forum and a brief description of the issue in your email.
Thank you!
hi, is issue solved. please mark if solved as solution.
