I rendered pictures with AI processing in cartoon style and got a nice result. Now I render the same scene and get a completely different result, as if someone broke the styles
Hi there,
I apologize for the inconvenience this issue has caused. Does this only occur in this specific scene? Can you send us your D5 Render File? You may send it to support@d5techs.com and have it titled Clov-Forum DIfferent Style of AI Processing, thank you.
Thanks for the answer! No, I tried rendering another scene (it was also rendered earlier), without changing anything, still a completely different result. I’ll send the file.
Hi @fdsfserr
Thank you for sending the file. We got the same results. Just to confirm, these two images were generated on the same D5 Render Version, Right? Thank you.
Yes, you are right
Hi @fdsfserr
Our team also wants to confirm if you used the original unedited image for the second attempt. Or perhaps the first attempt image was used further then resulted to the second attempt image.
Hello!
In the attached files the second image is photoshopped (mix of the original render and AI cartoon render). The trees are not photoshopped. AI pictures for the second image are not saved. But you can compare the trees. You can see that they look different in the two images. In the model, these are the same trees. Both images were made using AI processing cartoon style in 1 iteration.
Hi @fdsfserr
Our team made some readjustments with the AI Style Transfer - Cartoon, which is perhaps the primary reason why there were some changes to the images you used. Currently, we have input some subtle refinements, which could be closer to what you were trying to achieve but certainly different from it. Thank you for your understanding!
