Hi Team - when deleting task it seems not do do anything. I have selected the trash icon and then warning show at top but no tasks deletes.
Am I missing something?
Hi, check if when you saved the scenes in a folder of your work, you don’t have to change their name of the scene, because you do nothing to erase the path of the scene made before.
Hi, sorry but I do not understand. When I want to delete a task as per snapshot above it does not delete. This is what I am referring to. Thank you for your reply.
Hi, I tried it on 2.10 and it worked fine.
↓This is the screen recording on my side.
2025-03-07 16-03-18.zip (249.2 KB)
Hi, maybe I didn’t explain myself well, I’m sorry for English, but when the one -written in red comes out, it means that you don’t find the images you made. I see that the images are called '01 - 02 -02a ‘, so when you made the renderings of these images, you saved them with a name, while on the D5 program window the images icons have the name in’ Scene 1 - Scene2 etc … '. To use IA they must have the path of when you saved them without changing the name in the image during the rescue. But if you want to change the name on the image icon you have to do it before saving the Renders, replacing the scene1 with 01 etc …, this error has happened to me too, I hope I was clearer
Good work
