No change occurs when decal is used and is not represented.
Hi there, I apologize for the inconvenience this issue has caused. Can you perhaps send some further information regarding this issue through providing some screenshots or video recordings? So we may be able to assess and understand it fully. Thank you so much
Hi. I apologize for the inconvenience this issue has caused. If you insert a decal asset into the sloping ground, you might want to ensure the surface is on the normal side; otherwise, it won’t be visible. I tried recreating the surface in SketchUp, and it won’t show unless I reverse the face of the surface. Thank you.
You’re going to patch it right away, right?
Hi there. Im quite confused on your statement regarding the “patch”. ![]()
