Hello everybody
It would be great to be able to fix D5 window size. ( For example 1920x1080 or 2160x1440)
If you work on a resolution of 1920x1080 and set up scenes and open the same file on a different resolution the scenes will not be the same. (even if you use 2k or 4k)
The problem mostly affects wide monitors,
Best Regards
