D5 will work with 12Gb Gigabyte RTX 3080 Ti Vision OC, GeForce RTX3080Ti?
Sorry, for your question I can tell you that my laptop has a 12 Gb ram gtx 1070 card, D5 is a blast, I don’t understand how you use the program. I can understand to make a video of great effect maybe it takes a graphics card of great power, but I’m happy, sorry for the irony.
I’m just about to buy powerful computers for a big urban project.
And I don’t know - will the D5 work on a video card from Gigabyte, and not from NVIDAI itself?
Now I get it. In my opinion, a GeForce RTX card is always worthwhile, any card with a lot of ram, at least 12Gb, but the PC must also have this power, or even more,
I never D5 Tested for a large urban center, but I can tell you if you use a graphics program that gives you good results and the objects you go to put in the fail must be small, so you don’t load the files a lot. You will surely handle it well.
Thank you for your reply and your good wishes!
Then I wanted to tell you one more thing, this is a tip, there are the D5 scenes that you can download. Maybe an Urbana, which you can then replace it with your own, just for the light settings or something else.
Hi, Riccardo
Yes - I’ve already seen it. Thank you very much for your willingness to help!
Hello, D5 supports video cards from different brands, so it will work with Gigabyte 3080 with no problem. But I have two suggestions:
- First, D5 Render does not support multiple video cards. No need to turn on SLI or use multiple gpu for it.
- Second, I saw you plan to buy video card of “OC” version, which has overclock settings.
It is not suggested to run D5 Render with GPU/CPU overclocking…
Have a nice day!
Thanks,
Oliver
Hello, Oliver!
Thank you very much for your reply and very valuable advice!
Best regards, Dias.
