coordinates are wrong. Converted models do not fit properly with align.
Sure, can you screenshot it to show the problem? Did you use the converter or directly import the model? Which modeling software do you use? we will check it.
like. When we open old projects, the coordinates of newly imported objects are problematic.
similar to this. When we open old projects, the coordinates of newly imported objects are problematic.
There is no problem when I re-import the objects. it just doesn’t match with old projects. If we import the whole project again, there is no problem.
Can you screenshot some? Maybe it’s unlike this bug I attached above, we want to troubleshoot it, thanks for your feedback!
