Is this normal:
What are these files and can they be purged?
Hi, I did a check on my laptop, I’ve been working on it for a long time, I followed the path you indicated. There was nothing empty in that folder.
If you notice here in the attachment there is the same one as above in the string, there is only this ‘usr’ folder inside, the program has never given me problems.
Hi there, the “Pak” files are usually the assets that were downloaded in your D5 Render. If it is hindering you from opening it or it prompts an error, you might want to consider deleting it. This folder contains cache files downloaded from the online library to a local device, thus, assets need to be re-downloaded next time after deletion. Thank you~
Good to know. Thank you
