The D5 Toolbar in Sketchup 2018 is not showing since I last updated D5 Render. I’ve tried installing the .rbz file and the sync plugin and it still didn’t work. Is there any other way to make this work?
My workflow is ruined =(
Hi, try changing the Sketchup 2022 version, see if the D5 plugin works, then if you can’t change the program, have you gone to where Sketchup loads the plugins to see if it has a good activation?
Hi @veridiana.tersi , sorry for the problem.
What’s your plugin’s version?
Is D5 LiveSync in your SU Extension Manager enabled?
