D5 teams-material picker not working
Greetings everyone,
I’m currently working on a D5 teams projects with multiple work sets. I’m having problems with the eye dropper tool (material picker). Even though I’m selecting the materials on the work set and model I’m currently working it doesn’t select neither let me change or edit the material, this problem is the same in all of the project work sets even if i use the central file with the capability of edit all work sets at once.
I have checked the graphics card update, window update, turned off and on my pc and other pc’s multiple times, log in and out of the accounts, reloaded the model in the work set and still doesn’t work. This problem begun two days ago, we have been working on this project days ago without any of this problems.
PC Specs:
GPU: Nvdia RTX 4070
CPU: Intel (R) Core ™ i9-14900HX (2.20 GHz)
RAM: 32 GB
Hi @torrens Can you use the material picker on other projects? Which version of D5 Render and Launcher are you currently using?
Please share the D5 file and your log file so we can troubleshoot the issue further. Apologies for the inconvenience.
I am having the sam issue.
