D5 Sync still asks to update D5 Render even though it’s already up to date
I am using D5 Sync 0.4.8.0006 with Revit. When I try to start the sync, I get this error message:
“Please update D5 Render, then try again!”
However, my D5 Render is already updated to the latest version (2.10.2.0589). The D5 Launcher also confirms that no update is required.
I have already tried:
  • Reinstalling the latest version of D5 Render
  • Running Revit, D5 Render, and D5 Sync as Administrator
  • Selecting the installation path of D5 Render manually
But the issue still persists.
Has anyone else experienced this problem? How can I fix this so D5 Sync recognizes the updated D5 Render?
Thank you!
I am using D5 Sync 0.4.8.0006 with Revit, but I keep getting this error message:
“Please install the latest version of D5 Render, or select installation folder if it has been installed.”
I already have D5 Render installed, and I tried using Select Path to point to the installation folder. I even opened D5 Render from the Start Menu → “Open file location” and selected the folder, but the error still appears.
Things I have tried:
  • Reinstalling D5 Render
  • Running Revit and D5 Sync as Administrator
  • Selecting the folder where D5Render.exe is located
But the issue is not resolved.
Has anyone experienced this problem? How can I make D5 Sync recognize my installed D5 Render?
Thank you in advance!
Hi @u.yagcitr
The new plug-in for Revit supports D5 Render 2.11 onwards. Since you’re using 2.10.2, this might be the one causing the error prompt.
  • Additionally, can you confirm if using the previous version of the plug-in can be used normally?
Can you please follow these steps:
  • open D5 into a blank project manually
  • click start sync——if all work normal,close and exit D5.
  • click start sync to relaunch D5,check result if the error prompt still appears.
