D5 Sync ignore Cinema 4D texture tag projection. It use only UV projection which doesn’t work for objects created by C4D generators.
UV.zip (694.8 KB)
UV.zip (694.8 KB)
Hi @Smolak
The Tag section only supports the “projection is uvw mapping & uses default values” case; other parameter situations are not supported, so the uv in your file synchronization Render is different from the one in C4D.
