Could you describe more details about your issue?
I guess that’s one problem isn’t it? Are you referring to the loss of hdri after your restart? Did you lose your hdri after reboot? Can you tell me if your hdri is from the D5 library or imported externally?
Also, please check if you have enabled the smooth mode?
yes after restart or reboot i have lost , i am using hdri d5 library
this button always on
I may need to ask you some questions:
- Did you have a crash or flashback with this file before you rebooted?
- Did you add the HDRI from the D5 library and then use this HDRI from your local library?
- Are there any non-English characters or special symbols in your file storage path?
- Which HDRI are you using, please let me know the name of it.
sir i have change my file path where my hdri and other files loaded then problem has finshed thanks for your suport
Glad to receive your feedback!
