What version of D5 are you using? Could you also provide a screenshot of your D5 System Info so we can check your hardware and software setup more accurately?
i, thank you for your help.
I have already checked everything you mentioned.
I did what you suggested, and I am sending the screenshot of my D5 System Info as requested.
Thank you for sharing your System Info screenshot. It should normally be able to run D5 Render without issues.
I just want to confirm a few more things so we can narrow this down:
Does the issue still persist even after you reinstalled D5 Render?
Is D5 installed in the default installation path, or did you install it in a custom path?
Is this issue happening only when trying New/Open inside D5 Render, or do you experience anything similar when launching or opening projects through the D5 Launcher?
