Many users use drive C for system only files and this drive is relatively small compared to other. This cause that I even can’t start rendering process because this D5 temp folder can grow to 20GB.
I think that D5 should use system temp folder location or workspace settings inside D5.
It looks like you’re asking whether it’s possible to change the roaming folder configuration, similar to how Autodesk products handle it.
Unfortunately, this is not supported at the moment. Currently, temporary model and asset files can only be stored in the default directory: %appdata%/roaming/temp.
We’ve forwarded this suggestion to our team
Moved this forum topic to Ideas and Requests for everyone to see
