3ds max and D5 Render use “C:\Users\UsrName\AppData\Roaming\Temp” folder for LiveSync. How can I change location of this folder if I don’t have enough space on my disk?
During the installation process of the program and in the settings, I selected a different drive wherever possible. The program and working files are located on a different drive, but the temp folder still remains on the drive “С”.
Unfortunately, this is not supported at the moment. Currently, temporary model and asset files can only be stored in the default directory: %appdata%/roaming/temp.
- We’ve forwarded this suggestion to our team.
- You may also check this Feedback from a user in the Ideas & Request group. D5 Render ignore system temp folder = huge amount of data on drive C - Ideas & Requests - D5 RENDER FORUM
- To clear these files, normally, reopening D5 Render is sufficient. However, if you choose to delete them, it is advisable to do so while D5 is closed rather than while it is running.
