D5 render converter problem
Hello.
The convert process in 3ds max gives such an error.
Have you experienced this situation?
What is the reason of this?
abd5d564-84d0-4739-ab41-7abb4e5e157c
hello, i have the same problem with 3ds Max 2023. Working well only 3 days, with complex scenes…!!! I full desinstall D5 Plug, clean residual files, and reeinstall again, but the problem persist…, any alternative
solution…?
You will d5a converter. I use, not problem.
But, this is a real problem. they should fix this problem.
Hi mate, have you checked this? you may need to delete that file in the corresponding folder.
D5 Plugin Converter SKP for 3ds Max 2023 EXCEPTION CATCHED IN D5Export. Error Parsing root table: expected keys, tables, whitespace or comments, saw “/u0000” - Get Help / Tech Support - D5 RENDER FORUM
Hello. I tried too. Unfortunately. It didn’t work on my pc.
