D5 has always worked correctly. Since today, I’ve been having serious problems with the license. I keep getting logged out and can’t access the Pro content. Loading from the library takes significantly longer, and inserting my own FBX into the scene after importing also takes a very long time. Are there server issues on D5’s side? I’ve restarted my router. I haven’t changed anything about my internet connection. Everything’s working fine. Only D5 seems to be having issues.
The only server issue that was encountered last weekend was regarding the AI Tool. Are you still experiencing this problem? This only occurred yesterday, right?
I think my internet provider is changing IP addresses. I’ve set a static IP address on my router. It seems to be working for now.
That might be a solution to the problem.
Thanks for your tips. I’ll try it out at home. However, I think this might be the same problem as the other users have already reported. You wrote back then that version 2.10 would be improved here. However, it seems that’s not the case. I have version 2.10 and I keep getting logged out of the current project again and again.
Indeed, we did improve this in the recent 2.10 update. But I would like to emphasize that this feature addresses normal short-term network fluctuations. Therefore, normal short-term network fluctuations should no longer result in watermark issues for users.
Otherwise, these may not be momentary network fluctuations, or your D5 Account was logged in on a different device if watermark assets are appearing completely after the render.
Anyway, were you able to do the cmd prompt that I mentioned previously? Let me know if this has addressed the issue otherwise, I may need to collect your log file and try our network tool inorder to troubleshoot this issue further.
Thanks for your answer. I work on two PCs: one at the office and one at home. Up until now, I’ve only ever closed D5 on one PC. On the other, I had to log in again. Yesterday, I logged out at the office before closing the program. It worked. I wasn’t logged out at home last night. Maybe that’s the solution. I’ll try the cmd prompt this evening as well. I’ll get back to you.
Thank You and regards
