I was working on a project and it suddenly crashed, after that I can´t open it again from the saved file. It opens for a second and the crashes.
Reading the forum I saw other people having the same issue
RTX3060Ti
i7 11700KF 11th
32gb RAM
I erased the scatter folder and it opened, but if I try to make a new skatter or use the brush it crashes. I was working with no problems with scatters before the first crash
I apologize for the inconvenience this issue has caused. Is this crash file-specific? If the problem only exists with the current project or some of the scene files, it is likely that the file is too heavy and is taking up too much video memory, exceeding the load of your current device, and you need to lighten and optimize your file.
- If the file fails to open, please delete the ‘f2’ folder under your WorkSpace path and then reopen the archive. Once it’s open, refrain from updating the assets until you have lightened your scene file by deleting some assets, including procedurally generated vines. This will help prevent it from crashing again due to excessive video memory usage.
I erased the scatter folder and once the file opened I saved it with another name and it worked fine with the brush and scatters. I guess there were something on the file that made it very unstable
