D5 sync and loading takes so much time than usual and even with small files. Some times program stopped responding. How to fix this issue?
I apologize for the inconvenience.
- May I know which 3d Modeling software you are using?
- Does this occur to all files, even with a simple basic shape model?
- Does this issue occur only when D5 Sync is activated?
Note: If you’re using SketchUp, we don’t recommend using the D5 Sync Plug-in since the latest version of the Live-sync plug-in has already incorporated the same features; hence, it’s best for you to use the Live-sync version.
Hi, thanks for your response!
I am using Rhino 7, yes it doses even with small file. Sometimes it loads up to 10mins.
Also, if I try to open only D5 without syncing, still the same issue, and stops responding.
I also noticed AI enhancer takes more time than usual.
I apologize for the inconvenience. So basically, this issue occurs in both by:
- Opening D5 Render (without plug-in)?
- Activating the plug-in takes a lot of time to load.
Can you perhaps send us the following images/information?
- System Information - please include the D5 Render Version
- VRAM
- Memory Speed
- Which Rhino Plug-in Version?
