D5 deletes my imported files
I have a very recurring problem: Because when I start my previously worked and saved D5 project, the next day I want to continue working on it, I find that when I open D5 my SKP model appears deleted from the file and the imported elements also appear active as lighting but floating, does anyone know how to solve that? It should be noted that the files are stored on a server
Hi there, did you use the converter to sync it or import the model to D5 directly?
when you need to edit the file, do you open the file from the server directly, or move it to a local place then work on it?
If the former, then the changes you made may not fully sync or be saved to the server because we do not know what server you use and whether it is mapped to a local place.
If the later, then did you move back the edited files to the server to update it?
We highly recommend editing your work locally, then save the files to the server. You can also check the historical version to recover files, D5 back up the files every 10 minutes.
