A couple of issues I noted upgrading to 2.5 from 2.3:
- coordinate of imported objects no longer aligned as before (was already a topic)
- section cuts render as if behind glass, with a lot of glare/reflections making the renders unusable
- Sketchup navigation is not aligned correctly in D5
- some embedded jpg’s in Sketchup no longer render in 2.5 while they did in 2.3
- textures do not align as before, probably a coordinates issue that is different and I don’t understand
Anyway going back to my still installed 2.3 version for now.
Thanks,
Alain
This is correct. I have experienced the same problems with textures.
Can this be looked into ASAP?
Thanks for the feedback, we will fix them as soon as possible.
Can you screenshot it to show the prroblem? are these faces reversed, overlayed or broken?
Are these jpg groups or components? Can you try to explode them in the Sketchup? if it still happens, can you screenshot it to show the problem?
Also, can you screenshot it? or send the model to us for testing? support@d5techs.com
Sorry for the inconvenience again.
Sure, can you screenshot it to show the details about the problem. we will fix asap.
