D5 creates folder structure when I open file that used to be somewhere else
At some point I changed the name of the top project folder where we have many projects.
Now, everytime I open a D5 file located under this new folder structure, when I close it I find a complete path starting at the top, with the old folder name side by side with the new folder name.
This is very dangerous because older and new top folder names are very similar and when someone deletes what seems to be the old duplicate of the main folder will easily do a mistake and delete the actual working folder with all the projects in it.
In summary,
I have opened the file directly form D5 file in the new structure folder and saved it on the new structure folder, yet it insists to recreate the old full path until it reached D5 folder (where it used to be).
Hello concepsys,
Sorry for the late reply. I tested and tried to reproduce the problem you encountered last weekend, unfortunately, we did not succeed to repro it. Can you please record a video to show us the problem?
In our case, we changed the name of “top project folder”, then reopen the file, and it just worked as it should be… Thanks for your comprehension.
