I’ve been trying to import a 500 frame .abc file into D5 and it crashes. I can get a 300 frame ani to work. The file opens fine in Blender. I am running D5 as administrator. Is there a limit to what D5 can import?
Hi @localstout,
This issue is probably related to Animation Frames.
If you import this abc file into 3dsMax and then export 30 frames, it is possible to import it into D5 (at this time the memory occupation is about 10G). However, your animated model seems to be over 500 frames, and the memory could be inadequate.
D5 Render currently is unstable to support so large frames, but we will optimise this. You could try to solve this kind of issues by reducing frames now.
Regards,
Leah
Thank you Leah! I want to import some vehicle models I made, at least now I know that there are some limitations.
