D5 crashed because of low vram while rendering
I need to recover the file… As i can not open the file anymore… It always gets stuck at 15-18℅
File size is almost 25gb. I use 4070
I just need help placing the renders… Its very urgent…
Hi, it can happen when the files are huge, you have to split the graphic design file to load it area by area with the layers of your program, open it one at a time. That is, synchronize the first piece, save it in D5, then gradually the rest. See if it works that way. Then there is another alternative, is to create each piece that you have inserted in your project “trees, furniture, people or at the Urban level many buildings” you have to save each piece in SKP or another format, then load them as objects in D5 starting from a basis of your project which is huge. position them on the right coordinates, I inserted a plan with a two-dimensional image of your project so it is easier to position it.I hope I helped you overcome the obstacle.
Hello! Could you please tell me which version of D5 did you use? I also suggest you can show us the system info.
BTW, did you use the D5 scatter in this scene? If you used this feature, it could be that the scatter asset is taking up too much resources causing the scene to not open, then you can send us the scene file and we will fix it.
You can share a link here or send your files to our email. (support@d5techs.com, please describe the problem and attach the link of this post to your mail)
