Hi i have been working on D5 since a month now, and i have worked on some heavy files, however there is a new issue where its crashing whenever i click on scene tab
Windows OS 11
AMD Ryzen 5 5600X 6-Core Processor 3.70 GHz
NVIDIA Geforce RTX 3070 Ti
Windows OS 11
Hello. Can you tell me the size of your ram? Usually, some big scenes lead to high video and memory usage. You can check the usage when you crash.
If your RAM usage is too high, try setting up virtual memory.
If your VRAM usage is too high, try reducing the use of high-precision mapping and assets. Also, try reducing the use of Tindal effect and depth of field. In addition, for plants in the distance, you can try to reduce the grass material, use textures instead, and hide some objects that are not in the rendered screen temporarily.
BTW, you can also try to update your video driver to the latest one.
